How to install a temperature sensor
Discussion in 'Sensors and Actuators' started by abuhafss, Sep 4, 2010.
  1. trobbins
    trobbins
    83
    Jun 15, 2010
    a) possibly within 3C - you will need to check if equivalent measurements with same material and meter have been made.
    b) depends on the thermal mating characteristic between the sensor and the job, and the issue of thermal mass of the sensor and time of contact. If you can get a good physical contact, and have a small mass (ie. pretty much just the thermocouple itself) then the contact time could be in the seconds for accuracy of 3C - eg. a meter probe. It's probably best if you don't change the clamp to be thermally conductive.
  2. trobbins
    trobbins
    83
    Jun 15, 2010
    ps with a) you would do comparative measurements with a thermcouple anyway to calibrate the remote sensing technique.
