How to increase current and maintain a constant voltage ??
Discussion in 'General Electronics Discussion' started by hajri, Aug 19, 2014.
  1. hajri
    hajri
    3
    Aug 19, 2014
    I need a power supply circuit with 12v and and a low current between 45 mA to 100mA ; so the problem that i have an old charger with 12V but 650mA; or amplifier a 5V usb voltage !! any solutions ??
  2. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Current is drawn from a power supply. The 650 mA current rating of your 12V charger is the maximum current it is designed to be able to supply. If the circuit or device that you are powering only draws 45~100 mA, then only 45~100 mA will flow. This is way under the limit for that power supply, so it will not be damaged.
    If the power supply is poorly regulated, and your circuit is not drawing much current from it, you may find that the output voltage is higher than 12V. It might be 15V or even as high as 18V. This might possibly damage the thing you are powering.
    Give us some more information and we may be able to be more specific. Do you have a manufacturer, model number, or photograph of the power supply? The device you want to power?
    hajri likes this.
  3. hajri
    hajri
    3
    Aug 19, 2014
    I need a power supply for this UHF amplifier
      File size:
      639 KB
      141
  4. (*steve*)
    25,480
    2,827
    You need a power supply rated at 12V and about 30mA or more. You would be best advised (by Kris above, incidentally) to measure the voltage in case it is substantially higher than 12V when unloaded. a 20mA load on a 650mA power supply may be insufficient to bring the voltage into range. If so, get a better power supply.
    hajri likes this.
  5. hajri
    hajri
    3
    Aug 19, 2014
    Thanks all of you ,i found this solution ,i simulate it and it work !!
