How to get at "menu" on Sharp TV set without its remote?
Discussion in 'Electronic Repair' started by robert casey, Sep 8, 2006.
  1. robert casey
    robert casey Guest
    I have a Sharp color TV model 13K m100 but no remote. "universal
    remotes" won't get me into the menu. As I want to reprogram the channels
    I get going up and down and to change it from cable to off air. Are
    there any internal jumpers I can jump to access the menu? Or is there a
    way to fake the proper remote say by using the RS232 port on my PC to
    drive an IR LED and a program that causes it to produce the correct
    on/off sequence of pulses to make the TV think it's seeing the proper
    remote (looked all over the web but didn't find this)? Sure I can buy
    the proper remote on ebay, but for $60?...
  2. kip
    kip Guest
    Oh Boy !!
  3. Sure. How will you know how to do this?
  4. Tech Data
    Tech Data Guest
    If you want to play McGuyver that's up to you but, if you'll go to
    Walwart and pick up the One for All 4 in one remote, use code 0093,
    I'll gurantee it'll work or you have a bad remote sensor or didn't
    program it right. I use one in my shop to check repaired units and I
    know that one will work fine.
    www.techdata-kicksass.net
  5. Unregistered
    Unregistered Guest
    http://winlirc.sourceforge.net/
  6. robert casey
    robert casey Guest
    Thanks, the One for All 6 remote one also works for this. So I wont
    need to play McGuyver after all..... :)
  7. Tech Data
    Tech Data Guest
    Kewl!!
