how to flip a relay by digital signal
Discussion in 'Electronic Basics' started by saurabh9, Jul 10, 2008.
  1. saurabh9
    saurabh9 Guest
    What would be an easy way to turn on a relay by a digital signal. The
    relay would be hooked to a 220 V AC device.
  2. neon
    neon
    1,325
    Oct 21, 2006
    flip flop changes states but for relay to change states all you need is remove power and re-apply power like a switch douple pole double throw 240v humm are you sure your relay is rated for that voltage and current i say that because of your question.
  3. Rich Grise
    Rich Grise Guest
    Drive the coil with a suitable transistor. Don't forget the catch diode!
    Cheers!
    Rich
  4. Bill Bowden
    Bill Bowden Guest
    Actually, the catch diode might not be needed. There's lots of
    capacitance in the windings of the relay coil which charges up when
    the transistor switches off and limits the voltage to whatever the
    capacitance is combined with the energy put into it. A 1 millihenry
    coil at 12 volts and 120 ohms will store 1/2 L* I^2 = 5 microjoules.
    If the winding capacitance is say 2000pF, the voltage will be 1/2
    CE^2= .000005 = 70 volts.
    Did I do that right?
    -Bill
