How to find voltage of electric motor?
Discussion in 'Sensors and Actuators' started by liomry, May 7, 2012.
  1. liomry
    liomry
    16
    May 7, 2012
    Hi all,
    I've just started into robotics and electronics and I picked up a broken R/C car and salvaged the motors out of it, how can I check what voltage / current they take? I've checked but nothing written or engraved on them , just + terminal on the drive motor and nothing at all on the other motor(guessing a servo since it was for the steering?)
    The car took 4 x 1.5v AA batteries and had two motors, a few leds and a 27MHz receiver. The steering motor is smaller than the drive motor and is flattened on top and bottom
  2. (*steve*)
    25,385
    2,772
    I would suggest the motors run from 6V
  3. liomry
    liomry
    16
    May 7, 2012
    Thanks Steve,
    Is there a safe way to test the minimum voltage for these motors or the current that they draw? I know V=IR but I'm struggling to bring this into the real world
  4. (*steve*)
    25,385
    2,772
    The motor won't follow V=IR, just use various voltages (under 6V) and measure the current. The current will change under load too.
