Hello there!
I have a problem in finding the relative temperature whenever different Current is pushed as input of the charging IC. IC number is PT116, I have used this in one of my mobile pcb for charging. Current drawing in output point of IC is 1 ampere, 1.5 ampere and 500 mA in Always 4.1volt DC. Input parameter is always same: 5volt,2Amp DC.
Now, when (1amp, 1.5amp,500mAmp), how much temperature will produce in the IC, can be calculated? I have seen the product's data sheet. It has a only a volt-temp curve,which is not helping me much. Urgent Help needed.
Thanks in Advance.
Thanks in Advance.
