how to find bias so that OP amp output range is max?
Discussion in 'Electronics Homework Help' started by only6512, Jun 8, 2014.
  1. only6512
    only6512
    18
    Feb 15, 2014
    hello,everyone , i have a question about (d) i just know that maxium output may be V_Bp2+|Vov7| mininum:V_BN2-v_ov9 can anyone help me? thanks ^^
    *by the way ,i want to check the answer to (c) my answer:max:5-|V_ov4|+V_t1;min:-5+|V_ov3|+|V_ov1|+V_t1 are my answers right? thans again^^
      File size:
      40.8 KB
      130
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,081
    Dec 18, 2013
    Can you explain What V_0V4 and V_t1 is. I would have thought for the max you should be taking away all relevant voltage and not adding them as in -V_t1 and not +V_t1? What are these voltages?
    Adam
  3. Arouse1973
    Arouse1973 Adam
    5,164
    1,081
    Dec 18, 2013
    Ah just figured your Vt1 is what is called VTN and is the threshold voltage. I am not sure but I think it should be this
    Max = VDD-VSD4+VTN and Min = VSS+VSD3+VGS1
  4. only6512
    only6512
    18
    Feb 15, 2014
    thanks for your reply!
    V_ov4 is the overdrive voltage of mosfet 4
    V_t1 is the threshold voltage of mosfet 1
    and your answer:
    I think it is the same as mine:
  5. Arouse1973
    Arouse1973 Adam
    5,164
    1,081
    Dec 18, 2013
    Yep Correct. I think the other question is asking you what bias voltages you need on the gates of the depletion Mosfets to give half supply point on the output, and in this case I think the output should be 0V. The other guys might read this differently. I think they mean symmetry and not actually maximum or minimum voltage.
    Adam
