How to find Area of Hysteresis?
Discussion in 'General Electronics Discussion' started by EFDG, Jun 11, 2016.
  1. EFDG
    EFDG
    33
    Jun 11, 2016
    Hello,
    I have learn some basic of hysterics in Physic lab i need help how to calculate area of the curve as i was not present in class.
    [​IMG]
  2. (*steve*)
    25,490
    2,831
    One approximate method is to simplify it into a parallelogram
    EFDG likes this.
  3. EFDG
    EFDG
    33
    Jun 11, 2016
    hello sir,
    Here is the calculator how to calculate area by paraloogram?
  4. (*steve*)
    25,490
    2,831
    try googling for "how do i calculate the area of a parallelogram?"
    EFDG likes this.
  5. EFDG
    EFDG
    33
    Jun 11, 2016
  6. (*steve*)
    25,490
    2,831
    yes
    EFDG likes this.
  7. EFDG
    EFDG
    33
    Jun 11, 2016
    open in chrome it ask for h and b
    how to get height?
    and shape is also different.
  8. (*steve*)
    25,490
    2,831
    Have you tried drawing a parallelogram which approximates the shape you have?
    EFDG likes this.
  9. EFDG
    EFDG
    33
    Jun 11, 2016
    yes i have drawn
  10. (*steve*)
    25,490
    2,831
    so now use the formula to calculate the area
    EFDG likes this.
  11. hevans1944
    hevans1944 Hop - AC8NS
    4,606
    2,151
    Jun 21, 2012
    For non-analytical areas like the one shown above, print the curve on heavy paper and carefully cut the outline out. Weigh the cut-out with an analytical balance. Compare the weight against a square or rectangular cut-out of known area. The areas will be proportional to the weights you measure.
    In actual practice, after cutting out the hysteresis figure, try to estimate the size of the square or rectangle that will produce nearly the same weight as the hysteresis figure. An iterative approach, trimming one edge of the square or rectangle until it closely matches the weight of the hysteresis curve, will provide the quickest results. Carefully measure the height and width dimensions of the square or rectangle of matching weight. The area is the product of the height and width.
    EFDG likes this.
  12. EFDG
    EFDG
    33
    Jun 11, 2016
    I will remember this trick
    as i dnt have weighting instrument
  13. EFDG
    EFDG
    33
    Jun 11, 2016
    you people are genius.
    I have done it is similar to square i think
    but the shape is of outer curve is slightly different.
    will it not make any lag in area?
    ok, what we conclude from this area while measuring hysteresis loop i was not in class at that time.
