How to Extend Digital Camera Battery's Life for 10+ Hours?
Discussion in 'Power Electronics' started by ChuckyNorris, Aug 31, 2011.
  1. ChuckyNorris
    ChuckyNorris
    4
    Aug 31, 2011
    I recently purchased a Mini DV VD80 Pocket Digital Video Camera:
    [​IMG]
    I would like to have it record 6 hours of continuous video footage. It has a
    Built-in Li rechargeable battery which lasts about 2 hours.
    Any ideas?
    Thanks!
    Edit: 8 GB microSD is the max storage capacity. 40 minutes per GB recording time = about 6 hours of footage.
    Also, the MINI-DV doesn't allow recoding while the battery pack is connected. Using an AC adapter converter to USB also doesn't allow recording since it must be the actual adapter with a mini plug.
  2. davenn
    davenn Moderator
    13,983
    2,015
    well unfortunately thats a really bad design. There's not much you could do without hacking into the camera and bringing the battery connections to the outside so that you could connect a higher capacity battery.
    Either that or get a camera that will support an external supply
  3. donkey
    donkey
    1,301
    56
    Feb 26, 2011
    this seems too small to add anything. a new case would be needed and then a bigger battery. thats the only way i can see it
  4. ChuckyNorris
    ChuckyNorris
    4
    Aug 31, 2011
    Is it possible to connect the Li battery (connected to the camera) to another Li battery, and have it charge and power the camera at the same time?
    Also, the battery is: 120 mAh 3.7V
    Would I be able to use a bigger battery (i.e. 2Ah 3.7V) to extend the time is stays charged?
  5. davenn
    davenn Moderator
    13,983
    2,015
    no, you have already said.....
    the only real choice is as I said in my first post :)
  6. ChuckyNorris
    ChuckyNorris
    4
    Aug 31, 2011
    I was thinking of trying something like this:
    [​IMG]
    How would I connect the battery to the circuit on the camera and still be able to charge it with the charger?
    [​IMG]
