how to determine the right voltage for led lamp?
Discussion in 'Troubleshooting and Repair' started by pharaon, Jun 3, 2019.
  1. pharaon
    pharaon
    234
    3
    Oct 28, 2014
    ok today i tried with 0.04 current and 2.6 voltage for 5 leds
    1- connected for only one led and the 5 light up together
    [​IMG]
    2- connect the first and last led and the 5 light up
    [​IMG]
    then i tried to light up 10 leds same current at 0.04 but i had to rise up the voltage to 5 V
    [​IMG]
  2. Alec_t
    Alec_t
    2,607
    686
    Jul 7, 2015
    That's a much clearer image and points to the LEDs being arranged as a series of 18 groups, each group having 5 LEDs in parallel. So I reckon you'd be looking at a power supply of at least 18 x 3V = 54V, capable of supplying a constant current up to 5 x 60mA = 300mA.
  3. BobK
    7,572
    1,633
    Ah, this finally makes sense. At least I was right before I was wrong!
    bushtech and Martaine2005 like this.
  4. Martaine2005
    Martaine2005
    2,229
    603
    May 12, 2015
    Yes Bob, you guessed about 60v ages ago!. So you were right!.
    Martin
  5. pharaon
    pharaon
    234
    3
    Oct 28, 2014
    how did you calculate this part?
  6. Alec_t
    Alec_t
    2,607
    686
    Jul 7, 2015
    See posts 10 and 12. If 66mA is the maximum rated current, it is always advisable to run things at less than maximum to prolong their life, so 60mA per LED seems reasonable.
    I'm still puzzled by your assertion that "they all share the positive line but the negative is every 5 leds". If 18 groups of 5-parallel are indeed in series then they can't all share the positive line.
  7. pharaon
    pharaon
    234
    3
    Oct 28, 2014
    yeah sorry about that, it's the opposite
  8. Alec_t
    Alec_t
    2,607
    686
    Jul 7, 2015
    You mean they all share the negative line? That still leaves the puzzle.
  9. pharaon
    pharaon
    234
    3
    Oct 28, 2014
    [​IMG]
    see that top thin line that all each group of leds share
  10. Alec_t
    Alec_t
    2,607
    686
    Jul 7, 2015
    I think you'll find that the light-coloured line is an insulating strip, not a power rail, and the darker areas are conducting paths connecting the groups in series. Can you confirm with a meter?
    Harald Kapp likes this.
  11. pharaon
    pharaon
    234
    3
    Oct 28, 2014
    yes that's true
  12. Harald Kapp
    9,034
    1,810
    This is what the circuit looks like (the polarity of the diodes may be reversed, I can't see that from your photos):
    Each of these meandered sections has 5 LEDs in parallel. The sections themselves are in series.
    All else has been said.
  13. Alec_t
    Alec_t
    2,607
    686
    Jul 7, 2015
    Conclusion: you'll need a ~300mA constant-current ~60VDC supply.
  14. pharaon
    pharaon
    234
    3
    Oct 28, 2014
    thanks every one
