How to count pulses per second ?
Discussion in 'Electronic Design' started by Mike C, Feb 13, 2007.
  1. Mike C
    Mike C Guest
    Hi, I'm hoping someone could help me create a very basic circuit which
    would:
    Count the number of pulses it receives per second (from a 555 timer,
    or a switch, for example) and if the number of pulses per second is
    equal to, or greater than 10 it turns on a transistor.
    So basically it should check every second if a clock frequency of 10Hz
    is being met - if so, a transistor should turn an LED on and keep it
    on for as long as 10Hz a second is hitting the circuit. As soon as the
    clock stops, or the frequency goes below 10Hz, it should turn off the
    LED.
    Thanks so much for your help !
    MC
  2. D from BC
    D from BC Guest
    Maybe give the LM2907 Frequency to Voltage IC a boo???
    D from BC
  3. Tim Williams
    Tim Williams Guest
    If it's constant, missing pulse detector. Can be made from a few
    transistors, or a few transistors and a comparator, or a single chip
    (LMxxx?) that does it. Hell, it can be done with the 555, IIRC.
    If it's not constant, then a decade divider like CD4017 set to reset every
    second (so you need another clock) and something to say that it's got enough
    counts or it doesn't.
    Tim
  4. Mike C
    Mike C Guest
    Guys, thanks alot for your response. In this case, the clock
    frequency is variable, so it would just need to count the number of
    cycles per second, and a missing pulse detector may not do it. I can
    see how a decade divider could work (I just dont have any lying around
    now, and would like to build it this week). What did you have in mind
    by doing it w/ just transistors and a 555 ... or a comparator .. im
    looking for anything crude and simple. :)
    Thanks again !
    MC
  5. Rich Grise
    Rich Grise Guest
    The dead simplest would be an RC low-pass or high-pass, and a comparator.
    You'll have hysteresis, if you don't want your comparator oscillating,
    and it won't respond very quickly, but it'll demonstrate the concept.
    Good Luck!
    Rich
  6. Guest
    Do this: put your clock freq into a counter, say a divide by ten.
    Every second, with another clock set to a freq of one second, look at
    the output of the divide-by ten-counter. If it overflowed, it was
    faster than 10 pulse per sec. Use an AND gate to check the output of
    the divide-by-ten and the one hertz second clock.
  7. Mike C
    Mike C Guest
    sdeyo... : An excellent approach. I will attempt this shortly and see
    if this works.. many many thanks
  8. Ken Smith
    Ken Smith Guest
    Is the "check every second" really a requirement?
    If not, the question can be rephrased as "if the pulses have a period
    less than or equal to 0.1 seconds"
    I suggest a couple of retriggerable oneshots like the HC122. Both are set
    for a 0.1 second time. The first is triggered simply by the pulse. The
    second has the AND inputs of the trigger used to combine the pulse with
    the output of the first.
  9. Ken Smith
    Ken Smith Guest
    LM339's come 4 to a package. You could make a one shot action by having
    one discharge a capacitor and another monitoring the voltage on it. This
    way, the first comparitor oscillating won't show at the output.
  10. Mike C
    Mike C Guest
    Ken: I'm not sure if "the pulses have a period less than or equal to
    0.1 seconds" can be considered the same thing in this case... because
    you could still have less than 10 pulses in a second even if they have
    a .1 sec period.. but maybe i'm not understanding how it would work..
    basically, two conditions have to be met for me:
    1. If and only if the pulse train coming in >=10Hz (10 "up" cycles
    per second with no particular duty-cycle pattern) only then turn on a
    transistor.
    2. Otherwise, if the pulse train count goes below 10 cycles at any
    point, turn off the transistor at once.
    So the output should be HIGH only if 10 cycles per second (or higher)
    are counted, otherwise output is LOW. Here is an example of the
    input and its required output : http://tiberian5.googlepages.com/
    Thanks for all your time !
    MC
  11. Guest
    I used this years ago to decode morse code. Determined if it was a
    dash or a dot by if the counter overflowed or not. Same with long and
    short spaces. Worked good!
  12. Ken Smith
    Ken Smith Guest
    Here's the real question: How long does the 10 cycles per second need to
    be there before we turn the LED on?
    If it is a full second then you need to have a system that measures the
    number of pulses in one second. If the measurement only needs to be made
    over a 0.1 second period then the dual oneshot idea will work.
    If at any point it goes below 10Hz, implies that you will react in 0.1
    seconds to a pulse being too late.
    We may need a 3rd oneshot to impose the rule that the pulses remain at
    10Hz for a full second, if that rule really exists.
  13. Tim Williams
    Tim Williams Guest
    Imagine this: the AC line frequency is 60.0Hz or so. It varies a bit. Yet,
    there are many household clocks which keep time precisely by this standard.
    Why aren't the power companies screwing these all up? Because, although the
    frequency itself may not be precisely regulated, the number of cycles per
    day, let's say, *is* kept in check. Although the clocks may cycle faster
    sometimes, they also cycle lower sometimes, keeping it accurate over long
    average periods.
    The same works here. You can tap out nine pulses really quick, but if no
    tenth pulse comes before this counting second finishes, your counter is
    going to say fail. The average pulses per second is still ten, but they
    didn't come evenly. THIS is the question we are asking you.
    If the pulse length is roughly equal for all ten pulses (i.e., the rate
    doesn't change much during that second), then a missing pulse timer type
    circuit will work very simply. It will not work if the pulses are
    significantly displaced (as elaborated above), because that long empty space
    between the first 9 pulses and the 10th will trigger the timer to send a
    fail.
    What is your signal source?
    Alright. Then please, don't call it hertz -- if you must, call it _average_
    hertz. The reciprocal duration (i.e., Hz == 1/s) of each cycle varies, and
    could be 2Hz or it could be 50Hz, so long as the average during that second
    is 10Hz (10 pulses per 1 second, explicitly so).
    Again, if it changes slowly (perhaps 9.7 to 10.3Hz), a missing-pulse
    detector (set for perhaps 0.103 or 0.104 second trip time) will suffice for
    reasonable accuracy. Which is another concern- how accurate must this be to
    exactly 10 cycles? Are the cycles what count, or the time or frequency?
    ....And it'll take one second to reach this decision, correct? Obviously it
    can't know if ten cycles have passed in that second unless they have.
    (Arguably, you could have a circuit count the average *continuously*, with a
    time constant of one second. Even a simple RC integrator would accomplish
    this, roughly speaking. But this also reduces to a missing pulse detector.)
    That looks like it is varying pretty widely, though the Hz input count makes
    me feel like the input is some constant frequency during that count period.
    Tim
  14. Fred Bloggs
    Fred Bloggs Guest
    Your requirements are contradictory. On the one hand you insist that one
    second be the shortest interval over which you make the determination of
    once" if <ten pulses. Sampling a count at one second intervals cannot
    possibly considered "at once." You will never get anywhere with this
    kind of confusion, and it would be best if you describe the circuit in
    specific terms of just exactly what it is instead of giving everyone
    your hopelessly confused idea of the essential abstraction.
  15. Ken Smith
    Ken Smith Guest
    The requirements are only, sort of, contradictory. They could be read as
    the 10Hz or greater rate must be maintained for a full second for the LED
    to go on and a single late pulse turns it off again. Basically, this puts
    a one second oneshot into the design where true on its output means the
    LED is off.
