How to convert VHDL / Verilog code to layout?
Discussion in 'Electronic Basics' started by boki, Feb 2, 2004.
  1. boki
    boki Guest
    Hi, All:
    Could you please tell me or give me some hint to .
    Thanks a lot!
    Boki.
  2. Monk
    Monk Guest
    Well that depends alot on what software you are using, some will do
    the conversion others will not. Sometimes your best bet is to create a
    symbol for that chunk of code and then you can insert it into a new
    layout. but it will look like one chip not a series of gates.
  3. boki
    boki Guest
    How about Cadence?
    Thanks a lot!
    Boki.
  4. Monk
    Monk Guest
    sorry Boki I've only used MaxPlusII and it did what i explained there.
  5. boki
    boki Guest
    It is ok, thanks a lot!
    Boki.
