How to convert a decimal to 4bit binary in BASIC language?
Discussion in 'Hobby Electronics' started by sommes, Apr 22, 2006.
  1. sommes
    sommes Guest
    I am using BASCOM AVR and I would like to ask.
    How to convert a decimal to 4 bit binary digit.
    For example.
    Convert 7 to 0111
    Convert 8 to 1000
    Convert 9 to 1001
    Thank you very much
  2. Binary is Base 2 each bit in binary has the decimal weighted representation
    1, 2, 4, 8, 16
    2^0 = 1,
    2^1 = 2,
    2^2 = 4
    2^3 = 8
    2^4 = 16
    Eg to convert 9 to binary
    9 divided by 16 = 0, with 9 remainder (4th bit is 0)
    9 divided by 8 = 1 and 1 remainder (3rd bit is 1)
    1 divided by 4 = 0 and 1 remainder (2nd bit is 0)
    1 divided by 2 = 0 and 1 remainder (1st bit is 0)
    1 divided by 1 = 1 and 0 remainder (0th bit is 1) = 01001
    Let Num = the number to be converted to binary
    Let n = the number of bits you need (integer)
    let array of bits(0..n) (integer)
    Let rem = remainder (integer) = 0 (start at zero)
    let res = result (of modulus division)
    You can have a loop (for i = n to 0)
    algorithm.... not exactly basic code
    FOR i = n to 0
    res = Num mod 2^i *** mod is modulus
    divide function in basic
    rem = Num- [res * 2^i] *** compute the remainder
    *** get what's left over from the divide
    bit(i) = res *** store the result in the bit array.
    Num = rem *** do it over again with what's left over
    Next i
    *** display bit result ***
    For I = n to 0
    Print bit(i); ** display each bit individually
    next i
    print
  3. Ken Taylor
    Ken Taylor Guest
    I'm not 100% sure that this is the same syntax as BASCOM uses, but you
    should be able to adapt this:
    'assume x is the decimal integer to be converted to binary.
    dim x as integer
    dim y as string
    a = 1
    y = ""
    do until x = 0
    if int (x/2) = x/2 then
    y = "0" + y
    else
    y = "1" + y
    end if
    x = int(x/2)
    loop
    x = val(y)
    inelegant but it works. I needed to convert decimal numbers to a binary
    string representation which is why it's like this. There's undoubtedly a
    nicer way to do it.
    Cheers.
    Ken
  4. Ken Taylor
    Ken Taylor Guest
    This is what I meant by elegance, and it looks like it's actually BASCOM (As
    I said, I don't know it myself). I paused for a cup of tea before I posted
    my example so missed this. <sigh>
    Ken
  5. sommes
    sommes Guest
    Thank you Joe, Ken and Alan. You guys are really helpful.
    I think I better explain what I am going to do.
    In this program, I require to read the 10bit ADC from AT90S8535 via 4 bits
    output from HT-12D(Decoder) and convert this 10 bits to display on three
    digit 7 segment display. A 74LS48 BCD to 7-segment converter is used. As
    Alan stated, a decimal can be used directly in BASCOM-AVR (I just found out
    today). For example, portd = 9, and the output will be 1001, which is
    correct value for BCD.
    I've finished the program, and working in the simulation, however, the 7
    segment can't display correctly as simulation, I think I didn't read the ADC
    value correctly.
    I knew It is little bit hard to understand, I will post my source code
    tomorrow (as saved in office computer).
    Thank you for reading my long message.
  6. cheers!
    Some times exlaining to others helps yourself understand the original topic
    a bit better.
    JG
  7. sommes
    sommes Guest
    Thank you Alan again.
    I've finished the 10 bits to 3 digit conversion with simple div and mod.
    I would like to ask, how can I get assemble the three lots of four bits from
    the
    HT-12D into a ten (12) bit word to get the correct value from ADC via radio
    transmission and display on 7 segment ?
    I just wonder, should I not using all 4 bit in HT-12E, and only use 1 bit to
    transmit the digitial signal to avoid the assemble in HT-12D?
    Thank you very much
  8. sommes
    sommes Guest
    Thank you Jasen.
  9. sommes
    sommes Guest
    Thank you Alan. I will try to work it out.
  10. sommes
    sommes Guest
    Thank you Alan and lionel. Now I am having a trouble with HT-12E to send 3
    different 4bits in same time.
