How to connect this transistor NTE199?
Discussion in 'Electronic Design' started by [email protected], Feb 24, 2006.
  1. Guest
    Hi all:
    I have a project that uses transistor NTE199. In this transistor the
    disposition of pins is strangely as it follows:
    e c b
    with the flat part in front of you. It is to say that in this
    transistor the base is not at the center.
    On the other hand the circuit says that a resistor must be connected to
    the central pin of the transistor.
    So the question is:
    How to connect this resistor to the transistor.
    1) To c
    2) To b
    Thanks in advance for any comment.
  2. linnix
    linnix Guest
    No ----------------------------------|
    It's a very common component. Perhaps your local high school science
    teacher can help you understand it. Rather than asking hundreds or
    thousands of people around the world.
  3. DaveM
    DaveM Guest
    If the circuit you're looking at specified that the transistor be a NTE199 unit,
    then connect the resistor to the center pin (Collector). If the circuit
    specified a different transistor, and the NTE199 is a substitute, then you'll
    have to research the originally specified part and see if the pinout is the same
    as the NTE199 part. If they have the same pinout, then you're home free.
    If different, then make the connection according to the specified part. That
    is, if the center pin on the original part is the base, then connect your
    resistor to the base pin on the NTE199.
    Think, man!!! Use your skull for something other than a hatrack!!
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
    address)
    Never take a laxative and a sleeping pill at the same time!!
