How to connect a earth leakage detection GFCI/ELCB?
bobdxcool
Mar 9, 2012
98
Mar 9, 2012
98
My specifications are as follows:
2 in phase 120V lines
1 Neutral
1 Ground
So, I should use a 240V GFCI, right ?
http://www.trci.net/products/shock-shield/user-attachables/high-power-gfci
This is the one I plan to use. 23250 003-1 GFCI
So, connections would be connecting one 120V line to the line wire on gfci, 2nd line wire to the second line wire on GFCI and neutral to neutral and ground to ground.
IS that correct ? Or, am I going wrong anywhere ?
