How to clean oxidized USB plug?
Discussion in 'Power Electronics' started by NVZN, Jun 16, 2020.
  1. NVZN
    NVZN
    12
    Dec 17, 2016
    How to clean it? I tried to use alcohol 70%, no avail. Only cleans a bit.
    Using vinegar? Or?
  2. dave9
    dave9
    899
    229
    Mar 5, 2017
    How did it happen? Prevention seems important.
    A mildly abrasive metal polish should do the trick, for example brasso (but I would try toothpaste first if you have no metal polish), but that is just a ground (and not strictly needed for USB function since there is another pin 4 ground on the contacts), so if it won't work you probably have a different problem.
  3. bertus
    bertus Moderator
    683
    237
    Nov 8, 2019
    Martaine2005 likes this.
  4. NVZN
    NVZN
    12
    Dec 17, 2016
    I left this sitting on a shelf for 6 months. And they got oxidized like that..
    Toothpaste? Just apply it to oxidized area? Leave it or brush it with toothbrush?
  5. Harald Kapp
    10,025
    2,138
    Brush.
    Toothpaste contains micro abrasive particles to clean teeth, works equally well with many other surfaces.
