E
Eric R Snow
Greetings All,
A couple years ago I installed the meter kit in my TEK 465B
oscilloscope. I have all the manuals for the 'scope but not anything
against which to test it. It seems to be OK but calibration would be
great so can anybody point me to a good place to buy the proper signal
generator? I'm just a rank amateur but the thing has beenh helpful. A
good example is how I tuned up my neighbor's generator after some hack
had messed up all the adjustments. I looked at the output from a 9
volt AC wall wart that I first plugged into the mains. I noted the
wave form (not a perfect sine wave, but bent over) and the frequency.
The frequency was correct for the scale I used so at least I know
that's working correctly. I then plugged the wall wart into his
generator and used both an optical tach and the 'scope to measure
frequency. Along with a DVM I adjusted the carb and governor so that
the generator put out 60 cycles and 120 volts with at least a 300 watt
load. Unloaded the frequency went up to about 66 cycles and the
voltage went up to about 130 volts. With a full load the frequency is
pretty steady and the voltage drops to 115 volts. He now loads it up
with a little space heater before he plugs in his fridge and some
lights. There was no way to keep the voltage above 105 volts and the
frequency above 52 Hz when the thing was loaded if the unloaded
frequency was 60 and the voltage 120.
ERS
ERS
