How to calculate R and C values for snubber circuit
Discussion in 'General Electronics Discussion' started by hca, Sep 2, 2012.
  1. hca
    hca
    15
    Aug 28, 2012
    Greetings,
    I am going to be using a push button to control the on/off operation of a 12 V DC motor which will run up to 10 A (steady state). To prevent arcing across the contacts, I intend to use an RC snubber in parallel with the contacts. My question is how do I calculate the required values for R and C?
  2. Harald Kapp
    10,821
    2,440
    Your question cannort be answered in general as the Snubber depends on the operating characteristics of your circuit (voltage, current, load, frequency). Have a look at this application note. I hope it helps.
    By the way: at 12 V I don't think you need a snubber at all. If you use a relay that's rated for this voltage and current (possibly automotive) you will not need a snubber. Arcing is not an issue at 12V.
  3. hca
    hca
    15
    Aug 28, 2012
    Thanks Harald,
    The application note was very interesting.
    I guess I won't need a snubber
