Fred B. McGalliard said:
There really is nothing to agree to. That's just the way things work. They
work that way so predictably that we don't call conservation a rule of thumb
but a law. It got this exalted status by being simply always right. If you
think you have found a way around it, something prevents it from working.
This one is simple. Try to figure out why you can't make a Maxwell's demon
some time.
BTB, you can make a heat engine, and use it to run a heat pump, and
construct a very nice thermal battery. The killer is making a really
efficient heat engine/pump without spending the GNP.
thanks, you have got my point
make my heatpump heat engine and heat pump both
I would prefer cold fusion type membrane to work as Stirling heat engine
and electrical energy generator both
just one used in reverse osmosis to make forced flow of warmer water
into tank with colder water
forcing water flow and incorporating the latest water fuel cell
invention, i get what I wanted,
free energy generated from a water, forced to flow from a tank with
higher temperature to a tank with lower temperature water.
Analogy to reverse osmosis and RO membrane is excellent .
With a special soluable supplement to water, I mean CO2 gas and special
RO designed membrane one could expect to originate reverse osmosis
inducted water flow, generating electric current.
I am really impressed by the last show of H2 fuel cells I attended.
I does really makes sense to work on cost efficient thanol/methanol fuel
cell membranes.
How to make a special RO membrane for a solution of CO2 in H2O
and to combine it with cold fusion , i.e. fuel cell membrane ?
Jack
Inventor of Tomosonography and Tomoultrasonography
______________________________
Global Inventors Organization
20 inventions for auction sale
starting bid $ 100 a piece
