How to build Circuit
EFDG
Jun 11, 2016
33
Jun 11, 2016
33
Hello,
If the supply is 24V and we need 8V at more current like 8A using than linear regulator what we can design how?
like voltage divider.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,878
Jun 21, 2012
4,878
The only way to get more current out than in is with a SMPS (switch mode power supply).
And you should also make sure that the 24 VDC power source can provide enough current to operate the SMPS that delivers 8 VDC at 8 A. That is 64 watts of output power, so input power capability needs to be about 70 watts (assuming about 90% SMPS efficiency) or about 3 A capability from 24 VDC power source. If more current is available from the 24 VDC source, say 8 to 10 A, then you could use a series linear regulator, but a lot of power would be dissipated (as heat) in the regulator: (24 - 8)(8) = 128 watts. That is why the SMPS solution is better because only about 6 watts is "thrown away" as SMPS inefficiency.
However, @EFDG you haven't told us what you are trying to DO. Perhaps there is a "better" solution,,, small animals in a rotary cage driving a generator perhaps?
EFDG
Jun 11, 2016
33
Jun 11, 2016
33
I am learning how to increase it current and learn how to design it.
