Jon G.
[satire]
How to Build an Inverter
I don't know for sure, since I've never built one. Someday I
hope to, though. I want to make one to hook up to a running car.
First I need a fast switch that swaps the teminals of the
battery from +/- to -/+ 60 times a second. The switch has to
handle 100 amps. For that I'd use two 1200watt SCRs. To tell
the SCR's when to turn on and off, I'd use a 555 timer rigged
for a 60Hz square wave. Then I'd run it through a 1:10
transformer, with the primary made of heavy wire able to handle
100 amps at 12 volts ac. The secondary would then put out 120
volts ac at 10 amps. Stick in a couple of capacitors here and
there, for the advanced signal conditioning model.
So there you have it. A rough 1200 watt inverter for $20 worth
of parts, that you can't buy for under $1000.00
[satire]
[satire]
