How to build a temperature control for soldering iron?
Discussion in 'General Electronics Discussion' started by kidthorazine, Jun 14, 2013.
  1. kidthorazine
    kidthorazine
    24
    Jan 20, 2013
    Is it possible to build a cheap temperature controller for soldering irons? What parts would be needed ? I have several soldering irons the lowest is a 15watt the highest is a 60watt and all are the pencil type. I would like to use it as part of a soldering station.:D
  2. (*steve*)
    25,497
    2,838
    It's not trivial. Probably cheaper to go out and buy one. I recall I have one that cost me under $50 on special.
  3. somanshumehta
    somanshumehta
    16
    Jun 22, 2013
    Just put a thermistor on your heating element,which will be measuring the temp and use a amplifier to amplify the signals,now u have a analog voltage ( 0 to 5V).
    now u need to calibrate your thermistor,please refer to the datasheet for details.
  4. Druzyek
    Druzyek
    5
    May 29, 2013
    "Just put a thermistor on your heating element"
    Can you please elaborate?
