How to build a 15,000 Gauss hand-held electromagnet
Discussion in 'General Electronics Discussion' started by Voltron, Feb 27, 2018.
  1. Voltron
    Voltron
    3
    Feb 27, 2018
    Hey guys,
    I'm new, and I had a basic question that you can probably help me with.
    I'm wondering if it's possible to build a small hand-held electromagnet shaped like a solenoid that is possible of producing a field of 15,000 Gauss.
    I'm familiar with the formula for the strength of a field produced by a solenoid: field strength = (permeability * number of turns * amperage) / length.
    By my calculations, if I can get a core with a u of 10^(-3), amperage of 5 from a Gates 5 amp-hour battery, and a length of 5cm, I would only need 15 turns.
    Am I on the right track?
    I've learned though that there's an issue with wattage.
    Apparently, because there's such little resistance in copper wire current will flow heavily and the watts will be high.
    Too much wattage and the magnet might catch fire or destroy itself.
    Any ideas of how to proceed?
    Thanks.
  2. Externet
    Externet
    760
    166
    Aug 24, 2009
    "Small hand held" means nothing; What is 'small' ? Like a clothes iron ? A marble ?
    A couple of proper permanent rare earth magnets canibalized from defunct hard drives will have that 1.5 Tesla strength. And truly hand-held. No batteries needed. Just attach a handle to its pole piece; do not remove it.
    "Issue with wattage"... Watts will be as needed for the desired field. How long should it be energized ? A momentary push button for a fraction of a second ? - minutes ?
    Once I made an electromagnet with the core of a microwave oven fed by the Discharge of a 100,000 μF 400V capacitor via a push button, to pull depressed dents on sheet metal. Tricky for certain dents.
  3. Voltron
    Voltron
    3
    Feb 27, 2018
    A solenoid the size of a thick bolt. 8 cm long and 2 cm in diameter or so.
    Yes, I'm already aware of that. They seem to be constructed from neodymium.
    Can you explain further, please?
    5 seconds at a time.
    What about running a 5 amp-hour lead acid battery through a magnet made from a microwave transformer. Would that work?
  4. BobK
    7,682
    1,688
    You get the strongest field with a nearly closed magnetic circuit with only a small gap, which is where the field wiill be strogest.
    What do expect to do with this magnet?
  5. Voltron
    Voltron
    3
    Feb 27, 2018
    I will use this electro-magnet to manipulate another magnet, a permanent magnet, for a short length of time, maybe for 2 seconds or so.
