how to bluetooth interface with microcontroller
Discussion in 'Microcontrollers, Programming and IoT' started by ronk4rompy, Oct 23, 2012.
  1. ronk4rompy
    ronk4rompy
    4
    Oct 23, 2012
    hi..
    i m working on some bluetooth project releted to ISRO.
    can any bady hepl me how to make interface bluetooth with any controller .........pls
    my aim is that i want do two bluetooth talking via two controller is it possible?
  2. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
  3. ronk4rompy
    ronk4rompy
    4
    Oct 23, 2012
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    They use serial communication, my initial link was actually wrong that is just the break out board, the actual module and info can be found here...
    http://www.ebay.com/itm/1pcs-Wirele...59?pt=LH_DefaultDomain_0&hash=item3a74b3519bt
    As for how to use them, there is tons of info to be found in a Google search, you can get the basic diagram from that link even though it's in Chinese... And I'm sure if you actually tried there is a English version of that datasheet... Dig around a bit almost all of these cheap Asian Bluetooth modules are identical so it's pretty easy to find info...
  5. ronk4rompy
    ronk4rompy
    4
    Oct 23, 2012
    yes i saw that but have any idea about it can possible that module is conntect or interface with controller or PIC with lcd..here the LCD is use for output data or msj
    indicatror
  6. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Well for both this module and an LCD you would be using serial communications... May I suggest you start exploring how to do serial communications with the compiler and PIC you are using... Do you have any programming experience? If not you have a long way to go, find a tutorial on on simple stuff like blinking an LED and work from there... In short learn to crawl before you attempt to run...
