How to bias a MOSFET amp?
D
Dbowey
John posted:
<< On Sun, 29 Aug 2004 19:34:57 +0100, Paul Burridge
Toobz? I was talking of transistors. Many tranny designs for Class C
RF utilize self-bias, too, but there is still no quiescent current!
What makes an amp Class C is a low conduction angle while operating.
When it's not operating, is has no class at all.
I can't recall any reference to support your last paragraph, but I have many
experiences to refute it.
Many, if not most, Class C amplifiers remain "on" while not transmitting; That
is, their Class C bias holds the control grid sufficiently negative to hold the
tube in cutoff when there is no excitation. When excitation is resumed, the
tube conducts. Obviously it is in Class C at all times.
Don
John Larkin
John posted:
Don
How can an amplifier be a Class C Amplifier if it's not an amplifier?
What's the difference between a totally cutoff class A amplifier and a
totaly cutoff class B amplifier?
John
K
Ken Smith
When dragon sleeps it still dragon, grasshopper.
Trick question! If the amplifier is totally cut off it isn't a class A
amplifier.
D
Dbowey
John Larkin posted:
< On 29 Aug 2004 20:05:41 GMT said:
John posted:
Don
totaly cutoff class B amplifier?How? An amplifier amplifies when it is driven by an appropriate signal. The
appropriate signal to drive the Class C amplifier is an RF signal from a driver
stage.
What's the difference? A Class A amplifier amplifies through 360 degrees. In
normal use it is *never* cutoff.
A Class B amplifier is *normally* biased so it is cutoff or has low idle
current with no signal applied, and conducts through 180 degrees with signal.
The Class C amplifier is biased to cutoff with no signal applied, and with
signal applied, conducts for less than 180 degrees and may be set to conduct
for as little as 90 degrees.
Why do you believe a Class C device is not an amplifier?
Don
John Woodgate
I read in sci.electronics.design that John Larkin <jjlarkin@highSNIPland
THIStechPLEASEnology.com> wrote (in <7fo6j05rp857et2n7tbqlp12bavl48qrrv@
4ax.com>) about 'How to bias a MOSFET amp?', on Mon, 30 Aug 2004:
He said surgeon, not sturgeon.
But, being male, PB is not even a potential source of caviar.
P
Paul Burridge
Hey ladies, gimme a break will ya? Don't make your PMS my problem. ;-)
John Fields
K
keith
OTOH, he's a good source of other slime. If you want ot go there, be my
guest!
