Categories
Platforms
Content
Almost. 69.8k should be 69K8, not 69R8.
what confused me was the schematics values and bags are all mixed up
plus alot of the resistor package values from different brands or wattage change the package numbers
3 digit code is primarily for 5% resistors
4 digit code is primarily for 1% resistors (or at least better then 5%)
Zero ohms is 3 digit code is 000
Zero ohms is 4 digit code is 0000
R is not used in 3 digit code
R is only used in 4 digit code
Yeah that would all be zero, or a shunt/jumper...
What are shunt resistors used for? to do what?
What are Jumpers used for? to do what?
No really
yea but i want to know what have you see shunt resistors and jumper resistors used for in circuits or in circuit designing
You're my google too from your own knowledge
What have u seen in your experiences
I have and will continue to use them on occasion in my own designs
and I see them all the time in other commercial (and hobbiest) designs
The techs at my jobs would just tell me that shunt resistors and jumper resistors are for designers that don't know what they are doing and its a poor design
Is this true or not?
and used for what? to do what
What were they used for please?
I have seen 1 ohm shunt resistors to know what the current in the stage is
I have seen those bare wire jumps that look like staples on PCBs , but i have no idea why a designer or circuit would need those and used for
What resistor value can I use in parallel with any resistor value thats on a PCB that can be like a break or open resistor ? would it be a 10Meg or what value please? that can be used with any resistor value in parallel?
No resistor at all is the best option for an open circuit.
Either to join stuff together that you can't route a track to (jumping over other conductors)
or to act as a configuration device (like a switch, but harder to change)
