how repair induction stove
Discussion in 'Troubleshooting and Repair' started by vrak, Dec 4, 2014.
  1. vrak
    vrak
    5
    Dec 4, 2014
    Hi All
    My incuction stove got spark near Plug socket while working
    Input : 230V 5A.
    An any one tell what are the Service Porcedure for Fault Rectification
  2. shrtrnd
    shrtrnd
    3,808
    511
    Jan 15, 2010
    Who's the manufacturer and what's the model number of your stove.
    The vast majority of problems I've found with these units is the actual connection to the inductive heating element.
    Check the induction coil connections and make sure they're making good contact. (WITH THE UNIT UNPLUGGED< NO POWER).
    I'd also be checking (WITH THE CIRCUIT BREAKER TURNED OFF), the power socket outlet itself. The socket contacts may be so worn that you have intermittent contact.
    Power socket outlets experience wear over time, and the socket manufacturer may not make the best quality sockets.
  3. vrak
    vrak
    5
    Dec 4, 2014
    Thanks for your valuable sugesstion
    Its Butterfly Make
  4. shrtrnd
    shrtrnd
    3,808
    511
    Jan 15, 2010
    Pay particular attention to the induction coil connections. I found that the AC causes vibration, and the contacts to the coil can work themselves loose.
  5. 73cat
    73cat
    7
    3
    Dec 30, 2014
    Try to contact service center to get help.
