How much voltage is needed to power this fan?
Discussion in 'General Electronics Discussion' started by Hadley, Aug 11, 2010.
  1. Hadley
    Hadley
    Aug 11, 2010
    I don't really know anything about electronics, but I have a simple question:
    Will I be able to power this fan with one or two AAA batteries? I know it is rated at 5v, but I was just curious to see if I could power it with less voltage.
    Hadley
  2. Mitchekj
    Mitchekj
    288
    Jan 24, 2010
    I would expect it to work, but don't expect to get anything close to the stated CFM. In other words, it will turn but it probably won't do a good job at cooling things. Looks pretty low power to begin with.
  3. NickS
    NickS
    367
    Apr 6, 2010
    It may turn slightly but don't count on it cooling anything at lower than its rated voltage.
  4. (*steve*)
    25,499
    2,839
    And don't count on the AAA batteries having much life.
  5. eem2am
    eem2am
    422
    Aug 3, 2009
    no you cannot use lower voltage than that as you will overheat the coils..........the inertia will stop it turning at the lower voltage....then there will be no back emf to limit the current,,,,and the current will be too high, ..also , you will not have the cooling effect of the fan turning.
