JohnR66
I have a 30watt "sping" type flourescent lamp. Current draw is .5 amp, or
60va (120 volts).
I understand that the electrical meter (rotating disk type) cannot read
reactive power, only real power drawn.
Reactive power it typically a voltage to current phase shift. The current
wave form from these CFLs is more of a high crest factor rather than a phase
shift. I wonder how the meter responds to this type of waveform?
Let me slide in another question. I have a fixture using 5 60 watt lamps.
This light is on 14 hours per day. I think we're still at 10 cents a kw/hr
around these parts, so I pay $12.60 a month to run this light (using 30 days
to calculate a month). I want to install a two 4' T8 tube fixture. I
estimate total power drawn would be 70 watts (two 32 watt tubes + 6 watts
loss in the electronic ballast. This should drop me down to only $2.94.
5 880 lumin 60 watt lamps give me 4400 lumens, what is a good lamp to use
that gives 3000K color temp, good CRI and and similar lumens?
John
60va (120 volts).
John
