Drew Cutter said:
This doesn't sound too bad , $$ wise. The ripping the floor up and
putting concrete might be different.
It's obviously easier to put in when pouring a slab the first time. So
much so that it's not a bad idea to consider putting tubing in any time
you pour a slab, if there's the slightest chance you might ever want to
heat the space the slab is under.
If it's a floor on joists, you can run around in the basement or crawl
space and attach the tubing (and aluminum heat spreaders, if you feel
the need) to the underside without ripping up the floor (you might need
to rip down the ceiling if the basement is finished).
When retrofitting, there are multiple options to simply build up from
the current floor, rather than "ripping it up", unless you have an
inflexible need to keep the floor height exactly the same. Depending on
the floor you have, you might also be able to cut grooves into the
flooring to run tubing in, and build up only a tiny amount.
But it's probably not the way to go if you were not planning to redo the
floors - baseboard fin-tube units or radiators are much easier to add or
retrofit than in-floor radiant is. I've seen some radiant installations
in the walls (or extending into the lower part of the walls), but again,
not very cost-effective if not planning to redo the walls.
Often the first most cost-effective route (if you have no solar heat
now) is to set up to heat your domestic hot water - you use that all
year round, and it's easy to integrate. Hot air collectors for winter
heat are often the next most cost-effective. This discussion is heading
a bit off-topic for alt.solar.photovoltaic, might make more sense to
move it to alt.solar.thermal
