How much energy stored in 350 farad cap?
Discussion in 'Electronic Basics' started by Eric R Snow, Jun 30, 2004.
  1. Eric R Snow
    Eric R Snow Guest
    I don't know much about electronics but do remember when even a 1
    farad capacitor was pretty big. Now, in the july edition of Nuts and
    Volts there is a news blurb about a 350 farad, 2.5 volt capacitor. It
    comes in a "D" cell size package. When charged to the max how much
    juice does this hold expressed in watt hours? Is that the right term?
    Maybe amp hours at 2.5 volts would be better?
    Thank You,
    Eric R Snow
  2. John Larkin
    John Larkin Guest
    energy = 1/2 * c * v^2. That's 1100 watt-seconds if fully charged, 0.3
    watt-hours. Even supercaps don't store much energy.
    John
  3. Bob Masta
    Bob Masta Guest
    And worse yet, the output voltage drops exponentially
    when you try to use that energy!
    Bob Masta
    dqatechATdaqartaDOTcom
    D A Q A R T A
    Data AcQuisition And Real-Time Analysis
    www.daqarta.com
  4. Eric R Snow
    Eric R Snow Guest
    So that means that if it could dump all it's energy in one second it
    would be 1100 watts?Tthat would be 440 amps at 2.5 volts. This cap is
    rated at 20 amps charge and discharge though. At that rate it would
    take 55 seconds to discharge. Of course it probably can't do that in
    the real world. With an ESR of 3.2 milliohms and 20 amp discharge
    current how long would it take to discharge this cap?
    Eric
  5. 43.75 s, precisely.
  6. AC/DCdude17
    AC/DCdude17 Guest
    X-No-Archive: Yes
    Why do you say the voltage drops exponentially?
    Assuming constant capacitance, E=V^2
    Stored energy drops exponentially if the voltage drops linearly.
  7. Bob Masta
    Bob Masta Guest
    The problem is that to get the voltage to drop linearly,
    you need a rising load resistance (ie, a falling current
    drain). For a constant load resistance, the voltage drops
    exponentially.
    Bob Masta
    D A Q A R T A
    www.daqarta.com
  8. AC/DCdude17
    AC/DCdude17 Guest
    X-No-Archive: Yes
    I don't understand your reasoning. Voltage does not drop exponentially
    as a function of stored energy.
    The function looks like voltage = square root of stored energy.
  9. John Larkin
    John Larkin Guest
    Backwards. Need falling resistance to get constant current to get
    linear voltage droop. (But that's still not constant power.)
    John
  10. Assume you have a cap which is being discharged through a resistor.
    The voltage across it at any time is
    v(t) = Vo * e^(-t/RC)
    where Vo is the initial voltage at t=0.
    The energy U across the cap as a function of v is
    U(v) = C * v^2 / 2
    Thus,
    U(t) = C*(Vo*e^(-t/RC))^2/2
    = C*Vo^2*e^(-2t/RC)/2
    Clearly, as time goes by, both voltage and energy across the cap drops
    exponentially. Since current is voltage over resistance, the current
    through the resistor also drops exponentially.
    Instantaneous power, P(t) = U(t)/t, so its dropping exponentially with
    t as well.
    P(t) = U(t)/t
    I'm guessing thats what Bob meant.
    Regards,
    Bob Monsen
  11. Ratch
    Ratch Guest
    From the Random House Webster's Unabridged Dictionary:
    ex·po·nen·tial (ekÅsp$ nenÆshÃl, -spÃ-), adj.
    1. of or pertaining to an exponent or exponents.
    2. Math.
    a. of or pertaining to the constant e.
    b. (of an equation) having one or more unknown variables in one or more
    exponents.
    -n.
    3. Math.
    a. the constant e raised to the power equal to a given expression, as e^3x,
    which is the exponential of 3x.
    b. any positive constant raised to a power.
    [1695-1705; EXPONENT + -IAL]
    Since the capacitor voltage is proportional to the square root of its
    stored energy, its voltage has a exponential relationship with the
    aforementioned energy and vice versa. Certainly it is not a linear
    relationship. Ratch
