| > The point remains -- why are you contemplating using 60m
| > extension cables?
| I live in a flat and my car is kept in a garage in a block which is
| in the yard. The garages do not have power and sometimes I might
| need to use a power drill, electric light, soldering iron, charge a
| run-down battery, etc.
[f/u set to uk.d-i-y as getting off-topic for other groups and definately
on-topic for this group; subject line changed]
Ah-ha! "How do I get electricity to my garage" is the real question you
should have asked.
This has been discussed before -- google for threads about garages without
mains power. Suggestions usually include a battery (recharged in the house,
possibly on a trolley for portability) with an inverter, or a small
generator. Photovoltaic (solar) panels are sometimes viable for keeping a
car battery topped up.
Especially as you have a 'block' of garages, it might be financially viable
to have a new public supply laid on to the block, as the cost can be divided
between all the garages, if other owners agree. Power to a garage is useful,
especially if remote from the house, and the cost of the supply would
probably be recouped in sale value. That might not be the case for a new
supply for one garage. A proper fixed supply will also allow garages to be
fitted with mains-powered alarms, which might help persuade your neighbours
to agree with the scheme.
| This is the layout:
| I'm on the third storey and my cable flex would be slung along the
| building for about 30 metres and be supported once where it goes
| out of my flat and supported again (at about the same height) where
| it leaves the building 30m later.
PLEASE STOP RIGHT NOW.
What you are proposing is wholly unacceptable. Ordinary flex and cable is
not designed for being self-supporting over this distance. The flex will be
under considerable mechanical strain at the supports. Have you considered
what happens when 30m of cable comes loose and whips through the air?
Extension lead flex is also not designed for permanent exterior installation
and is not completely waterproof or resistant to abrasion and uv light.
What you are proposing doing is fixed wiring and should be done according to
the regs for a permanent installation -- designed, installed, and inspected
and tested in full compliance with the IEE Wiring Regulations.
As I surmise you will also be running this supply across other people's
property -- even if only the freeholder's -- you will need legal permission
from them to do this.
| The next 15 metres of cable would be a sort of descent to my garage
| roof.
There are strict regulations over the height of suspended cables -- they
have recently been increased following, I think, the death of a BT engineer.
| The last 5 metres or so takes the power to where I want it.
| (I am using 30m + 30m because those are the lengths on my
| two extension reels).
And you are going to waterproof the connection between the two extension
reels how?
| In this scenario, I don't really need to protect the cable from
| accidental cutting or damage anywhere along its length as it runs
| along the building or in the air away from any likely harm.
On a domestic installation "protection by placing out of reach" is not
allowed as a means of protecting either cables or humans.
There are serious public liability issues with what you are proposing. If
anyone is hurt or killed -- even as a result of their own actions eg
vandalising the flex -- you will have to justify your actions in a coroner's
court, and possibly face a charge of manslaughter.
| For my *own* protection as a user of an applicance at the far end of
| the cable it seems that it might be better to put an RCD close to
| whatever appliance I am using. Is this correct?
| OTOH maybe a domestic RCD is so sensitive that it is likely to work
| perfectly well at the mains end even when I am chiefly looking to
| protect me at the far end?
I'm not going to say *anything* which could possibly encourage you to
consider what you are proposing any further. It frightens me
Owain
