S
Sammo
I am in the UK (so mains voltage is about 230V or 240V).
I have a reel of main extension cable made of 3-core 1.0 mm^2 wire
rated at 10 Amps. So the nominal power rating would be about 2,400
Watts. (Link to tech reference for the cable is below.)
Presumably the current carrying capacity or power delivery
capability of the unwound 30m length unwound is going to be a bit
less than 10 Amps/2,400 Watts due to losses along the length of the
cable itself.
Is the reduction in current/power carrying capability significant?
If so, then is there a rough guideline figure for available
current/power which I can use?
If I take *two* of these 30m reels then I can join them with the
standard UK 13 Amp plug and socket supplied on the reels. This gives
me an overall length of 60m. Taking into account losses, what would
be the current carrying or power delivery carrying capability of the
60m length if all the 60m cable is unwound?
Thanks for any info.
Sammo
Technical reference for the cable is HAR type H05VV-F3 x 1.00 mm2 -
(details at http://tinyurl.com/7y5xx)
cable itself.
Sammo
