How Many Transistors On A Silicon Wafer?
Discussion in 'Electronic Components' started by Watson A.Name - \Watt Sun, the Dark Remover\, May 16, 2004.
  1. I'm talking about discrete transistors, like a 2N3904 or 2N4401, not an
    IC. I guess it depends on the size of the wafer itself, which might be
    4 inch, or maybe bigger? Like they're making 8" and 12" wafers for CPU
    chips now. And then there is the size of the transistor die itself. I
    would guess that there could be a couple hundred dies on each edge of a
    square superimposed on the wafer, so that could be 200 times 200 or 40
    thousand per, give or take several tens of thousands.
    @@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@,@@[email protected]@[email protected],@@[email protected]@[email protected]@[email protected]@
    ###Got a Question about ELECTRONICS? Check HERE First:###
    http://users.pandora.be/educypedia/electronics/databank.htm
    My email address is whitelisted. *All* email sent to it
    goes directly to the trash unless you add NOSPAM in the
    Subject: line with other stuff. alondra101 <at> hotmail.com
    Don't be ripped off by the big book dealers. Go to the URL
    that will give you a choice and save you money(up to half).
    http://www.everybookstore.com You'll be glad you did!
    Just when you thought you had all this figured out, the gov't
    changed it: http://physics.nist.gov/cuu/Units/binary.html
    @@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@[email protected]@[email protected]@@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@[email protected]@@
  2. I have a selection of 6" and 4" wafers at our factory, and I'll have a check on
    them in the week.
    I believe that they are not discretes though, probably Ic's.
    What was interesting to me was that the print/etch runs off the edges with no
    attempt to trim the image to suit the wafer, so there are a lot of unusable dies
    around the periphery of the wafer.
    I had one framed a while ago, looks nice on the wall and makes a good
    conversation piece :))
    Peter
  3. I think the reason for that is that the imaging system is much like the
    eye of an insect. The single die image is duplicated multiple times by
    the imaging system, without regard for the wafer itself.
