P
Phil Allison
Hi to all,
just picked up a "dimmable" CFL from K-Mart, a Mirabella brand 15 watt
spiral type - price was reduced from $20 to $8, which is more like their
true value.
Connected via a standard triac (pulse fired) dimmer, it operates fairly well
with dimming down to about 10% of max brightness and just a little
flickering at one particular setting.
Using my " RMS Current Monitor" and CRO to examine the current waveform
revealed it to be very spiky over the whole operating range. At around mid
setting on the dimmer ( when the rms current draw was only 170mA) - there
were continuous, bi-polar peaks of ** 1.5 amps ** every 10 mS.
So the QUESTION is how many such CFLs can you safely operate from such a
dimmer ??
Wall plate dimmers are typically rated at 300 to 500 watts with incandescent
loads and use a 4 amp or maybe 6 amp rated triac - but ONE 15 watt
"dimmable" CFL draws the same continuous peak current as a 250 watt
resistive load.
I know small triacs may well have a single peak current ratings of 30 or 40
amps - but that is just for one surge that lasts only a few mS.
So what is the answer ??
Are users likely to experience failure of their dimmers if they run say 20 x
15 watt rated CFLs as the 300 watt power rating suggests you can ???
Remember, doing the above will result is continuous current peaks of 30
amps.
...... Phil
true value.
dimmer ??
resistive load.
amps.
...... Phil
