how many amps output
Discussion in 'General Electronics Discussion' started by conntaxman, Apr 1, 2013.
  1. conntaxman
    conntaxman
    89
    Jun 17, 2011
  2. davenn
    davenn Moderator
    13,813
    1,945
    hi John
    Not sure what these have to do with your strings of LEDS ???
    you have linked to a PIR motion detector
    Did you were the data given ?
    Item Introduction:
    •The sensitivity and holding time can be adjusted
    •Working Voltage Range: DC 4.5V- 20V
    •Current drain:<60uA
    •Voltage Output: High/Low level signal:3.3V TTL output
    •Detection distance: 3--7M(can be adjusted)
    •Detection range: <140°
    •Delay time: 5-200S(can be adjusted, default 5s +-3%)
    •Blockade time: 2.5 S (default)
    •Trigger: L: Non-repeatable trigger? H: Repeat Trigger (default)
    •Trigger Method: L unrepeatable trigger / H repeatable trigger
    •Work temperature:-20-+80°C
    see the hilited line .... these supply a TTL output to feed in to Logic IC's
    You are not going to control LED strings directly from these
    What are you trying to achieve ??
  3. conntaxman
    conntaxman
    89
    Jun 17, 2011
    Hi Dave, I just read about or now know that i cant just use these to turn on some leds. I thought that these had like a relay in them to turn on stuff.But i found a small cir. for them.
    The cir is only about 6 parts so I'll have to build that to go alone with it.
    Darn, i thought i could just use the pir sensor by itself.
    Tks for the reply though
    John
