I recently got an LM2673 Adjustable Voltage Regulator for a new more beefy power supply. However when I look at the datasheet under the Adjustable configuration, not the fixed output configuration, it clearly uses two fixed values for R1 & R2. Below I will attach the link to Texas Instruments and the datasheet. I'm not seeing how fixed values gives an adjustable value... Anyone that has worked with this IC or some related voltage regulator that could explain would be most appreciated.
http://www.ti.com/lit/ds/symlink/lm2673.pdf
