how i use this evaluation board DC2222A-A without PDA ?
Discussion in 'Sensors and Actuators' started by siavosh1, Apr 16, 2019.
  1. siavosh1
    siavosh1
    6
    Sep 4, 2014
    Hi everybody
    Until now , I design my ADC circuits with myself but i have new project that i need to use 32bit SAR ADC and i want send data from this ADC to the Atmega32 (8bit). as you know designing the PCB or drive circuit for this ADC`s is difficult and need time for finding errors and challenge with noise and ... So i make a decision that use the evaluation board but i haven`t any experience in it.
    the LTC2500-32 is good for me and have a good features. and i found the DC2222A-A is the evaluation board of LTC2500-32 .but in datasheet i found this eval board make for some PDA .
    I want use DC2222A-A stand alone without PDA . Can i do that or is it wisely ?!
    thank you for sharing your experience or advice with me.
    https://www.analog.com/media/en/dsp-documentation/evaluation-kit-manuals/dc2222afa.pdf
    https://www.analog.com/media/en/technical-documentation/data-sheets/250032fb.pdf
  2. Harald Kapp
    9,542
    1,968
    What do you mean by PDA? There is no reference to this acronym in the description of the eval board. However, this eval board is not designed to be used standalone but together with a data collection board:
    Can you do that? You should know. Technically it should be possible by emulating the interface to one of the data collection boards, but that will not be a simple task.
    Is it wise? Probably not. If you are going into the trouble of designing the required interface you may as well design your own analog board. That will be much less expensive, too.
    The same is true for the other eval board, the DC2390A-A (which requires a different host board than the DC2222A-A, but anyway).
    As an alternative have a look at the EVAL-AD7177-2SDZ eval board. This is for another ADC, still 32 bit, 2 channels, 10ks/s, interfaces to a pc via USB.
