How find the address of ptz camera
Discussion in 'General Electronics Discussion' started by mrel, Dec 19, 2020.
  1. mrel
    mrel
    102
    Jul 2, 2008
    Hello
    Got these china PTZ camera sell by Aliexpress with no brand name.
    Do anyone know how to find address of these PTZ ( pan , tilt ,zoom) camera to change address.
    Reason i ask is went have more than one PTZ camera hook to a DVR ,need to change address of the cameras.
    If don't change the camera address ,both camera will start turning at same time.
    mrel
  2. bertus
    bertus Moderator
    1,682
    652
    Nov 8, 2019
    Hello,
    That is the problem with products bought at Aliexpress.
    Is there ANY documention with the camera delivered?
    The seller likely does not even know what he is selling.
    He just wants to make profit.
    Bertus
  3. Martaine2005
    Martaine2005
    3,323
    910
    May 12, 2015
    There maybe dip switches on the pcb?
    Martin
    Bluejets likes this.
  4. Frankchie
    Frankchie
    141
    16
    Nov 14, 2017
    The IP address is probably dynamically assigned by your router. In any case, log into your router and display the connected devices. Sometimes the name displayed for each connected IP address will be helpful to determine the actual applicable device. If that doesn't work, generally the cameras have their mac address printed on the camera somewhere. The aforementioned router display will usually tell you the mac address for each IP device connected. Another method is to turn of the camera and see which address disappears from the router display or perhaps changes state to inactive.
    If you don't have access to your router there are free IP address scanners that run on your PC that will display all the addresses on your network similar to a router display. . Ipscan is one I have used in the past.
    dave9 likes this.
  5. Bluejets
    Bluejets
    4,648
    982
    Oct 5, 2014
    Don't see them in Aliexpress....do you have a link..?
  6. Harald Kapp
    11,280
    2,583
    THis is the situation once the camera has been registered to the local network, However, at first startup the camera typically starts up with an IP address of their own which you have to connect to to enter the credentials of your own network. At least wireless units work that way as far as I know.
  7. bertus
    bertus Moderator
    1,682
    652
    Nov 8, 2019
