How does this work?
Discussion in 'General Electronics Discussion' started by Name..., Apr 22, 2016.
  1. Name...
    Name...
    40
    Apr 6, 2016
    Can i please have an explanation?
  2. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Picture is not showing up. Please try again, or ask a more detailed question.
    What do you understand and what in particular do you have trouble with?
  3. ramussons
    ramussons
    356
    66
    Jun 10, 2014
    The IC is a comparator whose o/p is HI. When light falls on the LDR, it goes LO to trigger the 555.
    Not too sure about the 555 wiring........
  4. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Do you understand the remainder of the circuit?
    I think the best thing for you to do is look at a diagram of the 555. It's a simple device really...
    IC5 is a comparator. The opamp has a pair of comparators and a flip-flop internally.
    The opamps simply trigger when a voltage raises or drops beyond the point set by the voltage divider which is also inside the opamp.
    Take a peak, link the picture you are references, and ask again where you may get stuck ;)
  5. Colin Mitchell
    Colin Mitchell
    1,417
    312
    Aug 31, 2014
    "It's a simple device really.."
    Really ????
    It's one of the most difficult chips to understand.
    Why do you think I have written pages on the operation of the 555, just to get to understand it.
    Minder likes this.
  6. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    I can write a ton of pages on things you can do/build with a hammer...
    It's a simple device, it behaves in a known manner. Look up a block diagram to understand how the device operates, and use your imagination to think of different things you can do with it, or look up existing projects.
    Just because there are a number of projects that use a 555 different ways, does not mean that the 555 is complicated.
  7. Colin Mitchell
    Colin Mitchell
    1,417
    312
    Aug 31, 2014
    "Just because there are a number of projects that use a 555 different ways, does not mean that the 555 is complicated."
    How little you know.
  8. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    I will admit to not knowing a lot of things. It's what keeps me motivated to keep learning.
    Unfortunately though, you seem to feel like you know everything which leads to you making some ridiculous replies and blatantly suggesting ill-suited circuits from your website. I guess in these instances you *can't* be wrong... I mean, you have a website so you must know what you're talking about.
    So instead of pointing out how *wrong* somebody is, how about you share your paper on "Why Colin had trouble understanding a 555" with the rest of the class. Other's may find it useful.
    dorke likes this.
  9. AnalogKid
    AnalogKid
    2,370
    661
    Jun 10, 2015
    Does it ever occur to you, for just one millisecond, to disagree with someone respectfully? Do you even know how?
    ak
    dorke likes this.
  10. ramussons
    ramussons
    356
    66
    Jun 10, 2014
    Is this addressed to me or the OP? :D
    and I think the OP has been truly scared off..... :eek:
  11. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Sorry, that should have been for the OP ;)
  12. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    The 555 is wired at it's most basic way as a mono-stable.
    Pin 5 lacks the decoupling capacitor.
    When there is light("constant " )on the LDR the output will be "high" ,
    thus LED will light-up but the buzzer will be silent.
    Is this a bug or a feature?
    The op. should tell us...;)
  13. Name...
    Name...
    40
    Apr 6, 2016
    Guys dont worry, i know how this works. Sorry for the post from the first place.
  14. cjdelphi
    cjdelphi
    1,096
    104
    Oct 26, 2011
    The 555 is pretty easy to understand if you understand how it works
    To me, one of the harder chips to understand is a phase locked loop, i've tried to get the damn thing working several times lol
    Gryd3 likes this.
