How does Plastic-Encapsulate Transistors work?
Discussion in 'General Electronics Discussion' started by circuit12, Jun 12, 2018.
  1. circuit12
    circuit12
    3
    Jun 12, 2018
    Good day,all. I am currently working an project which need to use the plastic-encapsulate transistor.
    Here I am planning to use BCX51-10. And I google this part to find its related information. Here it is:
    Description
    FEATURES
    ? IC = -1A Continuous Collector Current
    ? Low Saturation Voltage VCE(sat) < -500mV @ -0.5A
    ? Epitaxial Planar Die Construction
    ? Complementary NPN types: BCX54, 55, and 56
    The information about this part is less,who can tell me how to use it?
  2. Harald Kapp
    9,488
    1,954
    Get a decent datasheet. Information on a marketplace as the one you linked to is usually marginal if not entirely useless.
    You use it as any PNP transistor as long as the parameters match,
    Why are you looking for a component first and then how to use it? That's not the usual way a circuit is designed. Normally you design a circuit that fulfills your requirements and then select the suitable components.
  3. FuZZ1L0G1C
    FuZZ1L0G1C
    367
    115
    Mar 25, 2014
    Salvaged component?....
