How does a Hands Free Temperature Measurement Device Work?
Discussion in 'Electronic Design' started by [email protected], Mar 11, 2005.
  1. Guest
    I was at the price club a few days ago and there was a device that
    allow
    a hands free temperature measurement. I believe it can measure down to
    150f
    (don't quote me).
    In general how is the temperature measured? Does ambient light contain
    temperature info, does it need to be compensated for? How does it
    ignore the temperature of the objects surrounding it? If the
    temperature is XXX degrees f, what is the corresponding wavelength
    of light?
    Boats_ranger
  2. Ian Stirling
    Ian Stirling Guest
    Not that simple.
    It typically measures the ratio of intensity of two different wavelengths
    of IR light, and gets it from there.
  3. At 'low' temperatures of 150F and if there is no convective contact
    and it appears to be an optical measurement, then it's likely this is
    a longwave IR measurement. A great many things can complicate useful
    measurements, though.
    Yes, in the relative energy distribution over wavelength.
    If it were measuring the apparent amplitude of a single wavelength,
    yes. Dual wavelength techniques (or still more than two) can measure
    the temperature by looking at the "slope" of the energy distribution
    instead of the simple amplitude and this type of measurement can work
    through uniform attenuation (so-called gray fog or interference that
    doesn't act selectively) and still read out reasonably well.
    Blocking can be done optically, but I think these things will often
    read out what amounts to about the hottest target within optical view.
    There isn't a single wavelength of light associated with one
    temperature. There is a distribution that often is taken to follow a
    "blackbody" distribution. You need to look up Planck's blackbody
    equation, Wein's and Rayleigh's equations (which preceded Planck's),
    and take a look at some of the displays of the curves at various
    temperatures.
    Jon
  4. Guest
    .Not that simple.
    How is this done? Are two different sensors used, which have different
    wavelength sensitivity? With this info. the ratio is calculated ?
    boat ranger
  5. Guest
    Does ambient light contain temperature info?
    I'm not sure what "energy distribution over wavelength" means, can you
    elaberate? for instance, in the case a single wavelength, how would
    energy be distrubuted? Does florescence play a role?
    boats_ranger
  6. Energy distribution over wavelength means what it says and, nearly by
    definition, it does NOT mean "single wavelength." The communication
    doesn't get much clearer than that. I'd recommend looking up those
    blackbody radiation curves for a start to see what I intend to mean.
    The pictures may help a lot where my words have failed. You may also
    find some JAVA procedures that will provide nice plots for any
    temperature you want to provide. Another term to look up is
    "emissivity," but only after you get the main ideas down.
    Fluoresence can be used to measure temperatures, as well. But it is
    an entirely different animal and it requires rare earths in contact
    with the target you are trying to measure.
    Jon
  7. Jamie
    Jamie Guest
    heat generates infrared light.
  8. Ben Bradley
    Ben Bradley Guest
    He means the amount of energy in each wavelength, as measured at
    different wavelengths. Take a small wire, put it in a glass container
    in which you replace the oxygen with an inert gas, and put a current
    through the wire. (Thomas Edison was famous for doing this) It heats
    up, and if you increase the current enough it starts to glow a dull
    red. That means it's not just generating heat, but visible light as
    well. Heat it more, it's bright red, then more and it's orange, then
    yellow. You probably know from experience that something glowing
    yellow (because the peak of its emission spectrum is yellow) is hotter
    than something glowing red (likewise with the peak being red), and
    this relationship holds at lower temperatures in the infrared range as
    well.
    The distribustion part means that when it's yellow it's also got
    some red mixed in, and also some green, but yellow is the brightest
    color at that temperature. If you match a distribution curve of color
    for a certain temperature to the observed levels of colors emitted by
    an object, the object is at that temperature.
    [Fluorescence. I once worked for a company that makes a lot of
    fluorescent light fixtures]
    Not in blackbody radiation. The name for this is incandescence.
  9. I read in sci.electronics.design that Ben Bradley
    If you find a lot of white powder on the floor, you've fitted a
    flourescent tube by mistake. They are very common.(;-)
  10. mike
    mike Guest
    I don't understand the "hands free" part. Do you mean non-contact?
    I've been messing with non-contact IR thermometers for a couple of years.
    There's the nasty little problem of emissivity. Seems that most
    everything I want to know the temperature of is shiny metal with
    emissivity near zero.
    A PEV Thermal Imaging Camera fell into my lap at a swapmeet last week.
    Kinda cool to see the footprints left behind when you walk barefoot
    across the floor. Haven't discovered anything useful to do with it yet.
    There's some interesting IR reading here:
    http://www.x20.org/thermal/DemoIrCameras.htm
    mike
    Return address is VALID but some sites block emails
    with links. Delete this sig when replying.
    Wanted, PCMCIA SCSI Card for HP m820 CDRW.
    FS 500MHz Tek DSOscilloscope TDS540 Make Offer
    Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
    Wanted 13" LCD for Mitac 6133 Samsung HT13X13-201
    MAKE THE OBVIOUS CHANGES TO THE LINK
    ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
