How do you connect a comper screen up to a usb cable or a 15 pin d-sub?
kad amd
Dec 12, 2010
Dec 12, 2010
how do you connect a comouter screen up to a usb cable or a 15 pin d-sub
i am wanting the screen which i have taken out of a Toshiba laptop be able to be put on a usb cable 15 pin d-sub if i have to use a higher pin d-sub pls say wat pin cable and please say if i can convert it into a 15pin or usb cable
pics here:
http://i1126.photobucket.com/albums/l603/kad_mad/DSCF6514.jpg
http://i1126.photobucket.com/albums/l603/kad_mad/DSCF6513.jpg
http://i1126.photobucket.com/albums/l603/kad_mad/DSCF6511.jpg
http://i1126.photobucket.com/albums/l603/kad_mad/DSCF6509.jpg
\http://i1126.photobucket.com/albums/l603/kad_mad/DSCF6508.jpg
http://i1126.photobucket.com/albums/l603/kad_mad/DSCF6506.jpg
http://i1126.photobucket.com/albums/l603/kad_mad/DSCF6505.jpg
http://i1126.photobucket.com/albums/l603/kad_mad/DSCF6503.jpg
http://i1126.photobucket.com/albums/l603/kad_mad/DSCF6502.jpg
http://i1126.photobucket.com/albums/l603/kad_mad/DSCF6515.jpg
this is a home project i want to do through summer idc how long it takes as long as i can complete it successfully. the whole idea of this was to pull apart and laptop which was stuff and take the screen to make as a hand held screen easy to move and eatch movies also i cane put dis up on my book shelf lie under it and watch is with out getting a saw neck and back. The screen will be used as a hand held screen (good for movies)
i also was going to connect to my laptop to make this work i forgot to add this in and ive seen things like this b4 where it was connected straight to the computer as a 2nd screen
also if you need any more inforamtion about this please ask and say wat information you want me to add in.
if you can help than you da best thanks also
