On Monday, 30 Aug 2004 21:52:22 -500, "Asimov"
|"Jim Adney" bravely wrote to "All" (29 Aug 04 21:16:28)
| --- on the heady topic of "Re: how do you clean your tip?"
| JA> From: Jim Adney <
[email protected]>
| JA> On Sunday, 29 Aug 2004 11:08:40 -500 "Asimov"
| >"Eric" bravely wrote to "All" (29 Aug 04 22:10:20)
| >It seems to work well that way in the experimenting I've done.
| JA> I'm surprised, but if you say that it has worked for you then I'll
| JA> just have to remain surprised.
| JA> In general, getting the solder to wet both the tip and the work is the
| JA> essential part of transferring heat to the work. Heat transfer without
| JA> wetting is much poorer and is quite often insufficient for the job.
|That is indeed what happens when a copper tip goes dry. The oxide film
|seems to be a very effective barrier to the heat transfer. By
|comparison, with Aluminum its oxide is only molecules thick and good
|metal to metal heat transfer occurs at the slightest application of
|pressure. From my experience, it did work well for desoldering but
|I'll have to experiment soldering with a thick Al tip. Maybe a
|slightly different method can be made workable, in contrast to the
|usual soldering common sense of wetting the tip and the work.
You seem to accept that the aluminium tip has an oxide layer which
prevents proper "wetting" contact with the solder at a joint but you
seem to be saying that you still get good heat transfer. It is a fact
that the efficiency of heat transfer is dependant upon the surface
area at the tip where it is in contact with the joint. If you have a
needle point tip the surface area at point of contact will be very
small and therefore the heat transfer efficiency will be very poor.
That is the very reason why "wetting" is essential for efficient and
reliable soldering and desoldering. The "wetting" action actually
increases the surface area in contact with the solder and therefore
heat transfer is at a maximum, even when using a needle point tip.
There can be absolutely no argument about this fact.
