How do I test my ac/dc adaptor?
My laptop isnt charging anymore. I thought before pulling apart the
laptop to check the connection inside, I would test the adaptor.
How do I test the continuity going through the adaptor? Does it need
to be plugged in and then test voltage, or just continuity. I have a
basic multi-meter.
Thanks.
P
Peter M. Groen
basic multi-meter.
Thanks.
You could always put your Multimeter in Current Mode and put it in between
the plus-line of the adaptor and the laptop. Make sure the Max-setting of
your Multimeter is higher than the maximum output of the adaptor or else
you blow-up the fuse.
If you have something that can withstand the maximum power output of the
adapter (Resistor, Lightbulb anything) you could always hook that up.
Measuring gets a bit easier that way.
Kind regards,
Peter
John Ferrell
By all means check things out that you can.
Most Laptops that have this symptom have a problem with the charger
connection on the motherboard.
These folks have helped me in the past....
http://www.pcpartfinder.com/default.aspx
basic multi-meter.
Thanks.
John Ferrell W8CCW
