How do I open a Dell AC Adapter?
Discussion in 'Electronic Repair' started by [email protected], Jan 2, 2007.
  1. Guest
    Does anyone know?!
    I have an Inspiron with a 90W adapter. Do you know how to open this
    adapter, I have to repair the cord.
    Thank you in advance!
    Igor.
  2. jakdedert
    jakdedert Guest
    Use a hammer...a rubber one preferably. Hold the device in your hand
    and tap along the seams. One of them should pop loose, and you can work
    along the seam with something like a putty knife or sometimes even your
    fingernail.
    If can't get a seam to pop in your hand, try laying it on the floor or
    bench. I've had good luck with holding the unit diagonally (lay a
    corner or edge on the bench) and striking the opposite corner or edge.
    jak
  3. Guest
    I tried it.. I'll try more..
    The thing is, the place where the cord comes out of the adapter gets
    hot and makes a strange noise (high pitched hiss). The green light does
    not come on and the charger does not charge my Laptop.
    Now Dell gave up on me.. a94in
    And I'm sure the problem is the cord, for when I move it - the sound
    changes.
  4. Guest
    It doesn't work..
    How much should I tap?!
    Sorry, thanks.
  5. PhattyMo
    PhattyMo Guest
    You need to "tap" it,not tap it..
    Give the sucker one good *whack*.
    The "diagonal" method has worked for me before..
    (I hate those damn glued-together-brick cases!)
  6. Guest
    I always use a gentle cut with a hacksaw when the drop and kick method
    doesn't work. I start at one corner and hacksaw thru till I get air.
    Then I use a strong screwdriver to pry the rest of the case open.
    Sometimes you have to hacksaw partway through the case all the way
    around before the screwdriver will pop the case open. It all depends on
    how cheap the case is made. You don't have much to lose, just be sure
    the power wall wart is unplugged when you do this <GG>.
    H. R.(Bob) Hofmann
  7. If you have a vise, you can try squeezing half of the case and see if it
    releases. Go slowly!
  8. jakdedert
    jakdedert Guest
    It should be mentioned that ac adapters are dime a dozen on eBay. I've
    always been able to replace mine for less than $20. A search on your
    model # will pull up more auctions than you can imagine.
    Beware a low price coupled with high shipping....
    jak
  9. jakdedert
    jakdedert Guest
    It's broke, for sure and you might not even be able to fix it. Get
    another one ASAP (see my post about eBay). Even if you get it fixed, a
    second adapter (to keep in your computer bag, leaving the other at your
    desk) is almost essential these days. They blow up, get lost or
    stolen...two is a minimum, IMO.
    Get another one...maybe two.
    jak
  10. I usually soak it for an hour or so in the freezer.
    Then I set a pocketknife along the crack of the solvent-glued seam and
    tap _that_ with a wee little ballpeen hammer.
    Go right 'round the thing 2 or more times.
    By then you should have one section of the seam that is willing to
    cooperate for you.
    And, by then, the case should be a little warmer to permit you to then
    use the knife blade as a pry under the now-loosened seam.
    HNY
    Jonesy
  11. Hi!
    Sometimes even that isn't enough. I had a bad Compaq AC adapter from my old
    LTE 5000 laptop. Something inside had been sizzling and finally went bang.
    The whole thing smelled pretty bad. I didn't think it would be fixable, as
    the wire coming out was already badly frayed and didn't make contact most of
    the time anyway. All I wanted to do was open it up to see what had gone
    wrong.
    I started gently enough with a small mallet. Then I tried a hammer. It went
    downhill from there quickly. Even several good whacks on concrete from a
    distance wouldn't open the thing. I even tried driving over it, and that
    finally got it to start coming open. Of course, by that point, the insides
    were not in good shape.
    William
  12. Guest
    Which AC adapter? Dell has had a bunch recalled due to this very
    defect. Check the Dell recall website or CPSC.gov to get the link.
  13. Failing any better way, whack it on cement until it breaks. It'll be easier
    to fix than if you saw it open.
  14. What makes you think that it's the cord. It could be a problem in the
    Laptop. But if you still want to get it open a pnematic drill often
    works wonders.
  15. Guest
    It's the cord because when I plug the adapter to the source, it makes a
    noise - and when I mess with the cable, the sound changes. The problem
    seems to be at the origin of the cable near the adapter.
    Anyway.. This case is dead. Dell won't help, because I'm in South Korea
    and they don't support my Inspiron 9400/E1405.
    I'll try eBay!
    Thanks a lot!
  16. Guest
  17. Guest
  18. Meat Plow
    Meat Plow Guest
    The cord would not hiss when it's broken.
  19. JW
    JW Guest
  20. Ah, yes, it will. Sometime they'll even shoot flames out.
