How do I find out the connection of the LCD I took out from a digital camera?
Discussion in 'General Electronics' started by Krist Neot, Jun 7, 2005.
  1. Krist Neot
    Krist Neot Guest
    In my old Olympus C900Z, it has very brilliant color display, and a
    resonable
    240*180 resolution. When I opened it, the connectors and everything are in
    good order. Now I need to find out the connection so that I can use it in my
    hobby projects. Is there a standard connection for such small LCD displays?
    Thanks.
  2. Art
    Art Guest
    Probably need to hack it a bit and see what results you experience. Maybe
    post to a "Digital Camera" N/Gs?
  3. Krist Neot
    Krist Neot Guest
    For such LCDs, is the display RAM usually implemented in the LCD panel
    or the camera manufacturer implements that in his camera's circuit board?
  4. Look at the panel's FPC (Flexible Plastic Connector). There should be
    a chip bonded to it -- that's the LCDC (Liquid Crystal Display
    Controller).
    Anyway, the LCDC generates panel voltages from incoming data. Most
    panels need something like the following:
    - Parallel data (6 or 8 bit)
    - Clock (anything from 500 kHz to 25 MHz)
    - Supply voltages. These are often suprisingly high, and if you
    connect them to the wrong pins you've got a dead panel.
    I work with small LCD panels (actually, I'm busy writing HDL for a
    LCDC at the moment) and I'll warn you: if you don't have a spec for
    the device you're quite likely to fry it or break it in other ways
    (for instance, most LC requires row-by-row voltage inversion to stop
    it from sticking).
    When we hook up competitors panels for testing we use a tool for
    hooking into the FPC to probe the signals being sent to it. It's
    pretty ridiculously expensive though.
    HTH,
    Peter
