How do I figure out what is jamming the RF signal in my garage
Discussion in 'Radio and Wireless' started by BHuber, May 22, 2018.
Thread Status:
Not open for further replies.
  1. BHuber
    BHuber
    May 22, 2018
    the remote control will not work for my garage, my car, and the bedroom above the garage.
    I’ve done a lot of troubleshooting and it seems to point to a possible signal jammer.
    If I drive my car away from my house.. the remote does work. If I move the bedroom remote to another room.... it works. All remotes work if they are within 1 inch of main unit (except the car,I have to drive away. Can someone offer any expertise?
  2. davenn
    davenn Moderator
    13,589
    1,872
    so it seems a problem with the car
    so what make and model ? what year ?
    what electronics does it have in it ?
    does it make any difference if the ignition is switched on (only) if engine is running?, if car is totally switched off ?
  3. shrtrnd
    shrtrnd
    3,734
    478
    Jan 15, 2010
    I'm still trying to decipher the issue as described(?)
    I'm reading a problem with the remote, then there are multiple remotes, then there's apparently a 'main unit'.
    Maybe I'm just dense and missing something, but can you offer a little more clarity about exactly what's wrong?
    davenn and kellys_eye like this.
  4. KJ6EAD
    KJ6EAD
    1,114
    157
    Aug 13, 2011
    If it's a remote control for a garage door opener, make sure the antenna wire on the unit is intact and hanging straight down. It's helpful on this forum if you state specific brands and model numbers where possible.
  5. davenn
    davenn Moderator
    13,589
    1,872
    yes agreed
    there is a severe lack of clarity in the OP
  6. K9WG
    K9WG
    25
    6
    Mar 8, 2018
    To start eliminating sources of possible interference turn off the power to different rooms and see if that fixes it. It's amazing how much RF garbage some appliances can produce. I had a satellite receiver that put out a very strong signal right at 146.75mHz (ham radio repeater frequency). It wiped out any reception throughout the house...
  7. Nisar-von-Voltenbräackter
    36
    3
    May 23, 2018
    Have your tried turning off the main circuit-breaker to see if there yet is no continuity? (I presume there are no critical applications that must remain on.)
  8. PhilK
    PhilK
    3
    Sep 16, 2009
    I may not understand but I think I do. The first test I would make is to move your car away where the remote works. Leave the car take the remote & test it with the car out of the picture (test site). If this works then the car electrics is the problem.
    I am an amateur radio operator and in every case I've seen so far as the signal you want gets further away the interference blocks the signal even better. But, if both move away & the signal you want is stronger than the interference then the strongest signal wins over the weaker. So both signals must be moving away as you move the car.
    QED the interference is in the car.
    Good luck.
    Phil/KE3FL
  9. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    To me it sounds like some parts of your house are shilded. Have you noticed if other rf transmittions go through like cell phone for example or have you tried the remote with new battery or a more powerful one ?
  10. chopnhack
    chopnhack
    1,573
    352
    Apr 28, 2014
    If it was an issue with the remote while just in the vehicle I was going to mention that metallic film window tint sometimes decreases RF transmission... but as others have noted the issue is unclear and OP has not returned in two weeks - maybe they figured it out.
    davenn likes this.
  11. elebish
    elebish
    177
    12
    Aug 16, 2013
    Try turning off one item at a time. First your computer, then your wi-fi unit, your electronic dog collar if you are using one, the tv, the stereo, home burglar system, any test equipment you may be using, a tread mill if you have one, remote controlled lights or fans, and smoke detectors. If that doesn't point to the culprit, disconnect your car battery (all cars) and try again! Note: many electric companies use electric meters that transmit a signal to save them from having to send out a person to read your meter every month.
    Is your problem that your opener is not receiving (signal blocked) or remote signal being masked over by another signal? As a last resort, you may be able to change the frequency of you opener and remotes to see if that alleviates your problem. Ed.
  12. davenn
    davenn Moderator
    13,589
    1,872
    the OP hasn't bothered to return with an update
    and everyone is just guessing because of the lack of response from the OP to the questions asked
    @BHuber IF you return please PM me if you have more info to add and I will reopen the thread
Thread Status:
