How do I figure out these resistors?
xgabrielx
Jan 1, 2010
6
Jan 1, 2010
6
I was looking at 555 timer circuits. I can see what this does...it is supposed to turn the transistor on and off at about 10khz. But I haven't really looked into transistors yet. I'm kinda learning stuff either as I need it, or, like now, when I see something that raises a question. I guess the one closer to the IC is like the grid resistor on a vacuum tube? They haven't labelled them...what does the other one do? The one between the base and emitter? How would I calculate the values of both using this circuit as an example? Oh, and how critical is it? Surely there's a wide range of what works? I don't know how this will react as the battery voltage drops from the 9.8v or whatever of a fresh battery, but I'm just interested in the actual maths, not their specific circuit. I guess if they just use a value somewhere between a fully charged battery and a "dead" battery, everything will be within acceptable tolerances?
I haven't looked into transistors much, but I thought to use them as a switch, you just needed a current flowing from base to emitter, and that as long as it was enough current for that tranmsistor, then collecter to emitter would simply function like an open switch. (or closed..can never remember which way round, because it's a bad choice of word) Did I miss some things? I guess I did, bceause I don't see a point in those resistors based on what I've read so far. Is there some relationship between the base to emitter current and the collector to emmitter current that must be kept within a certain range? Is that the point of the resistor on the left?
Then, what's the one from base to emitter for? Is it some non-essential thing, or does it have to be a specific value?
KJ6EAD
Aug 13, 2011
1,114
Aug 13, 2011
1,114
I count 10 question marks. Would you care to focus on one?
xgabrielx
Jan 1, 2010
6
Jan 1, 2010
6
Well, I guess it can be narrowed down to 2 questions. What do they do, and how do you calculate what values are required?
Martaine2005
May 12, 2015
4,949
May 12, 2015
4,949
Hello,
They are both voltage dividers of sorts.
The 8k2 and 68k charge the capacitor. When charged the 68k discharges it.
The component values used determine the frequency, ie flash rate. on/off rate.
The datasheet explains the math involved Here.
Martin
xgabrielx
Jan 1, 2010
6
Jan 1, 2010
6
Oh, I know ;D I meant the two that don't have values next to them. Sorry, I should have been more clear about that
Martaine2005
May 12, 2015
4,949
May 12, 2015
4,949
No, you were quite clear.:)
But I cannot help with the math. I have a friend that helps me with that!!!
The resistor from the base to 0v is a pull down resistor. It is to do with leakage or noise from collector to emitter. It basically keeps the transistor turned off .
Would you believe I have edited this about 10 times!! . Because I don't wont to start a war!!
Only because I can't win it.:D
Martin
davenn
14,260
14,260
Jeez! Can we go beat this horse some more in this thread... already up to ten pages now.
LOL yup
PLEASE desist from any argument/discussion on that topic in this thread. ... anything further like that and I will delete those posts
cheers
hevans1944
Hop - AC8NS
Jun 21, 2012
4,880
Jun 21, 2012
4,880
I was looking at 555 timer circuits. I can see what this does... How would I calculate the values of both using this circuit as an example? Oh, and how critical is it? ...
The 555 has a "totem-pole" output. See attached PDF. The output on pin 3 is either pulled up toward Vcc or pulled down toward ground. You can use just about any value resistor in the range of 1 kΩ to 10 kΩ to provide base current for the transistor that is switching the inductor on and off. The resistor from the base to the emitter is optional. You can safely omit it. If you want to leave it in, choose any value greater than 1 kΩ.
  • ne555 internal schematic and block diagram.pdf
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
heavans,
How would a beginner learn if you try to "chew " it for him...?
xgabrielx,
If you want to learn, come back to this thread .
there is much more on this issue...
davenn
14,260
14,260
OK a move of several posts to a new thread and a deletion of a bunch of others
KEEP THIS THREAD ON TOPIC
please just discuss the purpose and values of the 2 specified resistors
GPG
Sep 18, 2015
452
Sep 18, 2015
452
The 555 will pull down much better than up So the b-e resistor is immaterial. The resistor from pin3 should saturate the transistor. If you calculate it based on a low beta this will do. The idea is called forced beta
http://whites.sdsmt.edu/classes/ee320/notes/320Lecture24.pdf
In your case the relay is 38Ω and the supply 9V so relay current = ~240 mA
Forcing beta to say 20 = Ib~ 20 mA
Under worst case the 555 Vout will be ~ V+ -1,5 and Vbe = .6v so the voltage available to drive 20mA is~7V
So 7V/ 20mA =~350Ω Nearest E12, 380Ω And that is being conservative.
eetech00
Nov 17, 2014
95
Nov 17, 2014
95
Basically, you need to know:
Base input voltage
Relay drive current
Gain of transistor
Hi..
Example:
Vb = 9v <--base input voltage (same as (Vcc) supply voltage)
Ic = 236mA <--Collector current (current to drive relay = 9v/38 = 236mA (estimate))
hfe = 100 <--Transistor Gain = 100
Vbe = 0.7v <-- Voltage drop across Transistor BE junction
How much base current to pass 236mA through collector?:
Ib = Ic/hfe = 0.236/100 = 0.00236
But leave headroom, so instead, use 300mA for Ic
Ib = Ic/hfe = 0.300/100 = 0.003
Base Resistor:
Rb = (Vb-(0.7v))/Ib = 9v-(0.7v)/0.003 = 2767
Use nearest value = 2.7k
Estimate Resistor from base to ground
10 * Rb = 27670 use 27k
Make sure Tip41c is on heatsink.:cool:
GPG
Sep 18, 2015
452
Sep 18, 2015
452
.Correcting error:
Forcing beta to say 20 = Ib~12 mA
Under worst case the 555 Vout will be ~ V+ -1,5 and Vbe = .6v so the voltage available to drive .12mA is~7V
So 7V/ 12mA =~583Ω Nearest E12, 560Ω.
https://www.fairchildsemi.com/datasheets/TI/TIP41C.pdf
beta may be as low as 30
Using a logic level fet makes things easier.
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
Base input voltage
Relay drive current
Gain of transistor
Hi..
Example:
Base Resistor:
Taking that circuit as a theoretical drill only.
Correction:
For the relay to be on, we need the Tr. in saturation.
(deep saturation that is ,not just on the verge of it)
The Beta we need is the minimum one (take into account temp,IC current, etc.)
for TIP41C,Beta would be 15.
BTW, this Tr. is an overkill for driving that relay.
VBE sat=0.8V
VCEsat=0.2V
IC=8.8/38=231ma
IB=231/15=15ma
So design for:
IB=at least 20ma.
VBEsat=0.8V
and that TR. doesn't need an heat sink at all!
