how do i drop voltage of a power supply
Discussion in 'Power Electronics' started by daniel barter, Jun 6, 2016.
  1. daniel barter
    daniel barter
    3
    Jun 6, 2016
    Hi I am new to electronics so go easy on me. I am trying to drop to voltage of my power supply / battery charger from 29v 5a down to 25v 5a. Is there a easy way of doing this? can I just use a diode and resistor on output? any advice regards dan
  2. Colin Mitchell
    Colin Mitchell
    1,417
    313
    Aug 31, 2014
    Just use some 10 amp diodes.
    daniel barter likes this.
  3. shrtrnd
    shrtrnd
    3,816
    518
    Jan 15, 2010
    I'm going to stick my 2-cents worth in here.
    I don't know your battery charger circuit, but some of them indicate a higher voltage when unloaded, than they do with a load. Just suggesting you verify that your power supply output with it's load, is still higher than you want, if you haven't done that already.
    daniel barter and Arouse1973 like this.
  4. daniel barter
    daniel barter
    3
    Jun 6, 2016
    Thanks for your reply, how many 10 amp diodes would I need?
  5. daniel barter
    daniel barter
    3
    Jun 6, 2016
    I have already checked that and as the charger is designed for lion batteries it will not drop below 29v
  6. hevans1944
    hevans1944 Hop - AC8NS
    4,608
    2,151
    Jun 21, 2012
    The forward voltage drop across each diode will be approximately 0.6 V to 0.7 V at 5 A current. So to drop 29 V to 25 V you need to drop 4 V across the series-connected string of diodes. Do the math: 4 / 0.7 = 5.7 ==> six diodes, or maybe seven diodes if 4 / 0.6 = 6.6.
    This is a "quick and dirty" way to drop power supply voltage. If you need a precision reduction, use a three-terminal voltage regulator with an external transistor to carry the 5 A. Many circuits available to search for and try out on the Internet.
    (*steve*), davenn and daniel barter like this.
  7. BobK
    7,682
    1,688
    And, no matter how you do it, you will need a heat sink since there is 20W to dissapate.
    hevans1944 likes this.
